How to get other particle attribute
3642 8 0- igou
- 102 posts
I tried to use “import Attribute” to get other particle's attribute. Give a integer number to the “point number” input then can get other point attribute.
But there is a problem, for particle the “Point number” is changed every frame. Can I specify the target particle base on a “ID” attribute, not on a Point Number?
If “Import Attribute”can't, any node can? ( just trying “Find att value by index”, but can't understand this node)
Or any idea can get other particle's attribute?
Hope some one can give me a idea, thank you!
iGou
iGou
- laiwayne
- 58 posts
- igou
- 102 posts
Hi Laiwayne, thank your reply.
yes I'm talking about VOP.
I'm wonder how to use ID to get other particle attributes. for example, when I give a integer “1” to Point number input, importAttribute will to find the particle which point number is “1” but I hope it is to find which ID is “1”, not number.
you mean I can hold point index even some particle die(just use ID)?
if you only have one particle system and you want your point index remain consistent in VOP, use ID attriubte.sorry I can't understand well.
- laiwayne
- 58 posts
- igou
- 102 posts
Hi Laiwayne, I checked your file. but it seen still to find point number not to find ID
I changed your setting LIFE to Cd, so can clearly to see the result.
as you can see in Console, the id:1 has a Cd {0.510}, but {0.510} is not id1's color, it's id'2's color,
because even I give a id value “1” Houdini will go to find which PT value is “1”…Orz
- 8833 posts
- igou
- 102 posts
- 8833 posts
it doesn't work with POPs for the same reason as pointcloud lookups or other VEX functions that need to sample geometry from outside using op: syntax
there are ways to do that by using POPs in DOP context and therefore having access to geometry from previous frame you can sample with op: context either in pops directly from outside or in SOP solver which operates on the same geometry as POP solver
some posts that may be helpful
http://forums.odforce.net/index.php?/topic/8637-point-cloud-in-pop/#entry67421 [forums.odforce.net]
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=124741#124741 [sidefx.com]
- igou
- 102 posts
