My viewport seems to have a lot of problems. It's not rotating correctly and a lot of Houdinis features are not working. Basic example is creating a box and adding Cloud rig. The box displays fine but you don't see any cloud in the viewport.
I had amd raedon 6970 HD and thought that was the problem after reinstalling 10+ drivers. So today I bought new 3d card and I have exact same problems.
I'm using Gforce 660 Ti
Windows 7 64 bit
Build 12.5.376
Viewport problems please help
4096 7 1- Finnur oktosson
- 7 posts
- PradeepBarua
- 443 posts
- Finnur oktosson
- 7 posts
- malexander
- 5205 posts
- Finnur oktosson
- 7 posts
- Finnur oktosson
- 7 posts
- anon_user_37409885
- 4189 posts
The viewport rotation could be the preference for ‘Tumbling Method’ - its sounds like you have ‘Classic Houdini Tumbling’ selected under Houdini Preferences/3d Viewport. Try the other options - ‘Standard’ will most likely be familiar. You can also ‘home’ the viewer onto an object by selecting the object and pressing spacebar+G
The rendering quality looks like your settings are too low. Try changing the levels of Transparent Sampling under Out/Mantra node/Properties/Sampling to 10 and also set the Pixel Samples to 6
- Finnur oktosson
- 7 posts
