how to create Maya's Goal without creep
   Views 3585   Replies 3   Subscribers 0
Hello everyone
I want to create an effect just like Maya's Goal and control position by uv.
creep is a good idea but I wish a way can do outside of POP, so I'm wonder can VOPSOP do it or other node can?
thank you : )
there is Creep SOP as well which can do that
or if you want VOPs then Primitive Attribute VOP does that
thank your Tamte
sorry for question this issue again.
Primitive Attribute VOP is like use “primitive uv” to find position. can we use “texture uv” instead?
I up a scene file. in this case the particle should look a array on whole surface not only on the polygon which primitive number is “0”.
goalUVTest.hip (118.9 KB)
