Why is my rendering so slow?
   4529   3   0
Hello, I was just messing around with Houdini FX and made a small animation of a cube sliding. When I tried to render it with a mantra node (1x1 pixel sample size and 1 max ray samples), I was surprised how slow it was! It's just a simple cube with a camera.
When it actually renders a frame it goes by fairly quickly. But it waits between each frame for a very long (more than 20 seconds) and seems like it isn't doing anything.
So I thought maybe my computer was too slow (laptop) so I moved to my desktop which has a 1GB Nvidia card and quadcore i7 and it still ran just as slow! Any ideas what the issue might be? I attached my file below.
box.hipnc (108.1 KB)
Super fast on my computer.
But dude don't push your cpu with big scenes like this !
(sorry I can't help you)
https://vimeo.com/obreadytom [vimeo.com]
that animation runs at light speed on my computer, not a new one either (amd64x2 6400 8Gb nvidia 9600GT) but then it is only a box moving between two points.
list you exact desktop pc spec if you want someone to point out the weak link would be my suggestion ;0)
silla
It may be a system kind of hiccup – Houdini starting the mantra process, or mantra trying to connect to the image viewer.
Try rendering a sequence to disk files and see if that's faster.
Mantra tries to connect to the image viewer (mplay) using a socket, so AV might get in the way (depending on your system).
Knowing the OS might help.
