newb ? velocity over time in pop vop
2974 2 2- alexpdennis
- 12 posts
- old_school
- 2540 posts
In the POP Force DOP, second set of parms where the noise is added, enable the Use VEX Expressions.
There is a preset down arrow menu button to the right of the editor window. There you will find a few presets. Try the “Amplitude By Age” option which puts down this:
// Ease in using age in seconds
amp *= smooth(0, 1.5, @age);
The smooth(min,max,variable) expression reads like:
The smooth function returns a value of 0 if the variable is less than the min value, an ease curve going from 0-1 for the variable between the min and max values, and returns 1 when the variable is greater than the max value.
So adjust the 0 and 1.5 to control when the 0-1 ease curve starts and ends.
- alexpdennis
- 12 posts
