Fur render not following sub-d geometry
   5269   8   3
Hi everyone,
I'm having an issue with my fur/hair render not following the contours of my subdivided head geometry as displayed in the attached images. On both the head geometry node and fur node I have ‘Polygons as Subdivisions’ enabled, however I have a feeling there's more to it than that for fur renders. Am I needing to append a subdivision node to my head geo prior to generating the fur perhaps?
Any help would be appreciated, cheers!
That is actually a good question, the way I solve this problem is subdviding my skin mesh after I do all my paints and combs but if you do this you loose all that inside the fur asset, so to solve this I save or lock my low mesh inside the fur asset and I use a attribute transfer to transfer all my attributes to the higher res mesh it works but involves a workflow where you have to do that every time you before rendering, makes sense?
I hope that helps but I am sure there's a easier way maybe someone here could share some ideas.
Cheers!
My may is use one displace map for fur,the map is generate from the subdivided obj
https://vimeo.com/user3971456/videos [vimeo.com]
Cool! that makes sense but how would you generate this map?
I think you can generate it by shop or cop just find distance between original obj and subdivided obj.
But i do it by mudbox cheek smooth target models option off,that's easier
Thank you both, I look forward to trying those methods out. Quick question on the first method though, where should I be sticking my low-res mesh inside of the fur asset when locking it down? Cheers.
-Apply a subdivide node in your skin geometry and bypass it;
-Inside your fur asset do what you have to do in your low res mesh combs, paints, attributes etc;
-Lock the very last node with your attributes;
-Unbypass your subdivide node;
-Transfer the attributes from the locked node to the subdivided geo inside the fur asset;
-That´s it;
Makes sense?
Makes perfect sense, and worked perfectly. Thanks!
the reason for this is that the fur node, will use the skin as the skin geometry.
the subdivide at rendering time is a property of the node that happen for render.
if you like this behavior like other packages you need to make a switch with between the low res and the subd mesh that is link to the parameter.
