Hi guys, I'm doing something wrong, but don't know what.
I want curvy deformation blur on my particle sim so I set the substeps on my popnet to 4. When I set my deformation samples to 4 on my mantra rop and render everything looks fine.
The problem comes when I cache the particles to disk. I set my increment value to 0.25 because I figure 4 substeps per frame is equal to a 0.25 increment. Mantra crashes. I've also tried a 0.2 increment on my rop with not luck.
What's up?
Mantra not calculating deformation samples
2463 4 0- kacheson
- 46 posts
- edward
- 7899 posts
- kacheson
- 46 posts
- kacheson
- 46 posts
- edward
- 7899 posts
To be honest, I'm not the right person to ask but if you set your deformation samples to 4 on the Mantra ROP, doesn't that mean it'll write out 4 samples to the IFD for each frame already? You can test this rendering few frames and see if the motion blur is what you expect? I'm not sure I follow the need to change the frame increment. And again, please submit your IFD if it crashes Mantra.
