Copy Objects
   2281   5   1
Hi guys,
I am trying to copy tubes on a grid but i need the tubes to “start” on the grid instead of halfway like in the image. How can I do it?
Change pivot of tube centre to bottom.
Or translate it up using transform SOP.
like PradeepBarua sad. here is a example.
tube_copy_position_04032015.hipnc (67.3 KB)
Thank you all for the help!
I know about this method and I tried it and it works, before this thread but because I want to see if there's other way besides this.
Once again thanks for the help
Another way could be to put down a transform SOP after your tube or whatever object and in the x, y or z translate type in the corresponding “-$XMIN”, “-$YMIN” or “-$ZMIN”-Expression depending on the global alignment of the object and the normals on the copy template.
In case of a tube use the z-channel
That way, no matter what input geo you have, the lowest point of the geometry sits on the ground.
MoveCenterToOrigin.hipnc (66.7 KB)
