How can I check the rendertime?
I haven't found anything in mplay?
I'm more interested in mplay then in batch rendering now.
Peter
Rendertime display anywhere?
3982 4 1- peliosis
- 175 posts
- jason_iversen
- 12672 posts
In the Mantra ROP, go to the Command field and click the little “+” icon - in the Output tab of the popup window that appears you can set verbosity options.
It'll add a "-V " flag to the mantra command line which'll cause Mantra to print stats to the console. You'll only be able to see this output if you launched Houdini from a shell on linux though. If you're running it from windows you must add another option to cause mantra to send the output to an additional window:
mantra -V 3 -o consolewait
-or
mantra -V 3 -o consolenowait
-or
- peliosis
- 175 posts
- jason_iversen
- 12672 posts
Seconds aren't all that strange
You're interested in the biggest number. The others mean “load time” and such.
- peliosis
- 175 posts
