Help please - Add Attribute in VOP - Type modifier
   3287   2   0
Hi guys, in Houdini 12 into the VOP node, adding the “Add Attribute” Node was possibile modify the type (see screenshot).
In Houdini 14 I used the Bind Export to create an attribute but I nedd to modify it as the 12, switching from “Normal Data” to “Vector Data”.
How can I do?
I attach some screen to show the Houdini 12 situation and the Houdini 14.
Thak you!
Ok guys maybe I found a walkaround and I want share it with you.
To obtein the same results of the houdini 12 I used a Bind to export the attribute and an Add Attribute to define the Type. So now it's working.
I don't know if this is the right way to do but actually it's going.
I'm happy to share with you and every suggestion is more than welcome!
Thank You!
Hi!
Nicely done I encounter the same problem and by using the bind export plus the add attribut as you said it works like a charm !
Thanks a lot!
