&& in group parameter?
   9902   11   0
Hi all,
In the blast sop group parameter, I say if myAttrib is greater than five OR myOtherAttrib is equal to “test”:
@myAttrib>5, @myOtherAttrib=“test”
What is the syntax for performing an ‘and’ operation?
www.kmcnamara.com
I don't think there is specifically AND operator , but as there is ^(except) and !(not)
you can do :
@myAttrib>5 ^!@myOtherAttrib=“test”
in other words group if myAttrib is greater than 5 except if myOtherAttrib not equals “test”
so that would mean if myAttrib is greater than 5 and myOtherAttrib equals “test”
and btw. for OR use just space, comas are not allowed
Great thanks. A little tough to read, but it works just fine for two conditions. Thanks!
My guess is that this doesn't work if you want to add a third ‘and’ condition, right?
www.kmcnamara.com
Why wouldn't it?
Well it doesn't seem to work with groups. If I have three groups that represent P.x>0, P.y>0, P.z>0:
xpos ^!ypos ^!zpos
is not equal to:
@P.x>0 ^!@P.y>0 ^!@P.z>0
Is Houdini evaluating things differently when I'm listing groups? If I just have two clauses, it works fine. The addition of the third is where it diverges.
Note, just corrected an error in the .hip
blast_expression.hip (65.6 KB)
www.kmcnamara.com
it looks like it evaluates the pattern for groups incorrectly (bug?)
the result with attribute ad-hoc groups seems to be correct though
remember you can always use Group SOP/Combine tab to do more complex logic using both groups and ad-hoc groups
Totally, just trying to streamline my larger setups and use as few nodes as possible
I'll submit the group eval as a possible bug.
www.kmcnamara.com
Btw the Group SOP's Expression evaluation is extremely slow compared to Wrangle SOPs. So if you can do it using VEX, you would see a much better performance if you care about that.
For anyone looking for a numeric replacement for && (e.g. selecting points between two values):
Group syntax uses '-' in the following manner:
@P.x = -0.05 - 0.05
(This will select everything having a position along x between -0.05 and 0.05.)
Resurrecting an old topic: Is this still an issue? Still no way to logically combine conditions for the groups like "@attr1=val1 && @attr2=val2"?
voidcoder
You should still be able to do
@attr1=1 ^@attr2!=2
Like mentioned above
Edited by tamte - Oct. 10, 2024 01:59:22
@attr1=val1 ^!@attr2=val2
Edited by HirotaY2 - Oct. 21, 2024 01:08:19
