Houdini Lens shader
   20249   12   5
HI Chaps
Anyone out there written any lens distortion shaders for Houdini i could steal - i ask as i don't have the skills for such a ting.
In particular a lens shader which copies the anamorphic and/or classic lens model from 3DEqualizer 4.
Muchas Gracias!
Director @ Valkyrie Beowulf
www.vwulf.com
https://linktr.ee/neilrognvaldrscholes [linktr.ee]
There is no way to apply lens shaders in mantra atm. Maybe it's possible to create a custom camera in HDK, but not lens shaders for now…
Aleksei Rusev
Sr. Graphics Tools Engineer @ Nvidia
bump,
Is there any update on this in v12? I am interested in writing some camera shader stuff as well.
thanks
It might not be exactly what you're looking for but if you click on the little gear in the top right corner of the camera parameters and select “Edit rendering parameters”. You should then be able to add the “Lens curvature” to your camera. It's fairly simple but might get you somewhere along the way.
I don't know about the anamorphic option in 3DE…
If it is a straight anamorphic and assuming that any lens aberrations have been removed (when processing the incoming plates), have you tried the default Camera Object's Pixel Aspect Ratio parameter?
http://www.widescreen.org/aspect_ratios.shtml [widescreen.org]
As was mentioned before, you can render with the Mantra lens curvature property or set the camera Projection parameter to cylinder (panoramic) or polar (panoramic) to render non-ortho projections and is only supported by the raytrace or pbr Mantra render engines.
As far as rendering lens aberrations, you could use an Atmosphere fog Object in your scene that is assigned a fog shader to distort the field of view of the camera. This is only supported with raytracing and with larger deviations you will have to fire more rays as your coverage will vary in the scene.
The Atmosphere Object with the Fog Shader is applied last, after the displacement and surface shaders are run. This is why it isn't ideal to render lens aberration as it can lead to too much noise.
Another approach uses a physically based approach where you actually model a real glass lens out of geometry and parent this to the camera and fire rays through the lens. This means you will be relying on the index of refraction of your lens which is present on the Mantra Surface and the Glass materials. By changing the index of refraction on the shader, you can alter the amount of distortion.
Lots of fun but I don't know if this is something to rely on in production. I say this because you are spreading rays to cover a much larger area of the scene and you would need to fire more rays to reduce noise.
If you do want to play with the physical model lens approach, model it out of NURBs surfaces and not polys for obvious reasons.
jeff
Jeff, thanks for the tips. At least it is good to know that certain things are possible.
However certain kinds ofprojection spaces might not be possible with the camera tricks. Is it possible write camera lens shaders with the HDK?
k
now, there is 3DEqualizer lens shader and a COP node available at orbolt store:
camera lens shader:
https://www.orbolt.com/asset/Keller::LDPKLenses::2.2 [orbolt.com]
COP distortion:
https://www.orbolt.com/asset/Keller::LDPKLensesCOP::2.2 [orbolt.com]
The assets can load 3DEqualizer lens models.
cheers,
christian
Someone talked about using lens shader to do render to uv with pbr. Have not tried that yet bit would be the coolest lens shader ever
-G
schnelli
camera lens shader:
COP distortion:
cheers,
christian
Awesome - i been away for a while; sorry for late reponse - this is great - thankyou !
www.vwulf.com
the orbolt otl's did not work properly, because the assets need to modify the vex content dynamically, but orbolt uses locked assets for licensing. That's why the demo version didn't work.
If anyone is still interested, the latest version of our houLDPK shaderset can now be found and purchased directly via our webpage:
http://www.keller.io/software/ [keller.io]
best,
christian
Is there any new options?
Look at Houdini's own lens shader as an example:
https://www.sidefx.com/docs/houdini/nodes/vop/physicallens.html [www.sidefx.com]
There are tips in the docs on making sure your lens shader is backwards compatible with Mantra:
https://www.sidefx.com/docs/houdini/solaris/karma_lens_shader.html [www.sidefx.com]
