find closest point with pcopen vex
16871 8 3- Hossein_SHA
- 27 posts
hey guys
i have simple question how i can find nearest point in vex wrangle ?
like Afaq Sabri = https://vimeo.com/119124511 [vimeo.com]
diue d'amour
HonersforGod@Gmail.com
HonersforGod@Yahoo.com
http://www.youtube.com/user/SHA3254/videos [youtube.com]
- Enivob
- 2625 posts
Here is my latest incarnation of detecting my nearest enemy.
Maybe you can adapt it for your use?
Don't forget to close out the point cloud after use or you may leak memory.
Also check out the Proximity VEX code inside the Crowd Trigger itself. (dive into HDA)
float agent_search_radius = 3.0;
int enemyId = -1;
float last_distance = 100000.0;
string group = point(0,“agentgroup”,@id);
int handle = pcopen (0, “P”, @P, agent_search_radius, 1000);
int pcCount = pcnumfound(handle);
for (int i = 0; i < pcCount; i++) {
int pcId = pcimportbyidxi(handle, “point.number”, i);
if (pcId != i@id){
string pcGroup = pcimportbyidxs(handle, “agentgroup”,i);
if (pcGroup != group) {
vector pcPos = pcimportbyidxv(handle, “P”, i);
float pcDistance = length(pcPos - @P);
float current_enemy_health = float_point_attribute(“health”, i);
if (current_enemy_health > 0) {
if (pcDistance < last_distance) {
// This one is closer than last one.
enemyId = pcId;
last_distance = pcDistance;
pcclose(handle);
if (enemy_id != -1) {
// This is my closest enemy.
int close_id = enemy_id;
float id_distance = last_distance;
int enemyId = -1;
if (pcId != i@id){
enemyId = pcId;
pcclose(handle);
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Hossein_SHA
- 27 posts
I did it thanks to afaq sabri and Enivob …… Thanks
diue d'amour
- milesvignol
- 4 posts
- 8786 posts
as well to get just closest point you can use nearpoint() VEX function
https://www.sidefx.com/docs/houdini14.0/vex/functions/nearpoint [sidefx.com]
- mestela
- 1798 posts
On a related note, whats the most efficient way to find the closest point to a point? Eg, using this in a wrangle:
i@near = nearpoint(0,@P);
will just return itself. Having a look at the docs, I thought ‘aha, I’ll construct a group pattern to exclude @ptnum':
string me = itoa(@ptnum);
i@near = nearpoint(0,'!'+me,@P);
Ie, if the current point is 5, it creates a group ‘!5’.
This works, but scales terribly; anything over 1000 points slows to a crawl.
I can use nearpoints instead and run through the returned values, selecting the first one that isn't @ptnum:
int nears = nearpoints(0,@P,10,2); // find 2 points within 10 units
foreach (int i ; nears) {
if (@ptnum==i) continue;
@near = i;
It scales much better, just curious if I'm missing a cleaner way.
@near = i;
- 8786 posts
- mestela
- 1798 posts
- Hossein_SHA
- 27 posts
The remain issue is , i must move point to finde next point . that
The issue . Is there another way to do that without moving the point?
Mr . Alvaro did that with vop point cloud open node
diue d'amour
