changing the default name of hda
   6755   5   2
I started to make a cop hda but now the default node name is stuck to the first name i give to the hda : copPyTest
How can i change that ?
thanks
http://vimeo.com/vbkstudio [vimeo.com]
Try “Operator Type Manager” from the RightMouseButton Menu on the HDA.
(Right above “Type Properties”)
Then duplikate yout tool and set a new name.
Save everything and restart Houdini.
Insert your HDA again and go to Operator Type Manager again. Now delete the “wrong named” HDA.
This was the only solution I found after fiddling with the same problem.
If there is a better way, I'm interested, too :-)
thanks
I ll try that
Bump wondering if there is an easier solution to this. Want to change name of a lot of my assets
http://www.sidefx.com/docs/houdini/hom/hou/HDADefinition.html [www.sidefx.com]
there is copyToHDAFile() function so you can automatize the process over a lot of assets
There should be an easier way to do this. I ended up creating a new hda and copying all the contents of one to another.
