VR Camera Pz & Options +
   6758   10   2
I try to render a depth map Pz with the VR Camera and i get this result :
I wonder if it is possible to have more option like the Octane Spherical (equidistant) Camera ?
For the project i am working on, i need a specific FOV (like 180*30 deg), and i don't know where i can change this values on the code.
In attachement a screen shot of octane camera option for VR, and my depth map.
octane cam
Hmm, doesn't look like you can modify the camera like that, you might have to RFE, or assuming the VR camera has been written as a lens shader, modify the code yourself.
Re the depth being wrong, you can define your own z channel by measuring the distance from Eye to P, and exporting that as an extra image plane.
Edited by mestela - June 5, 2016 11:58:13
Thanks for the feedback on the VR Camera. We currently don't support partial lat-long renders with the camera, though this control could be added. This will be added on Monday, ready in the next daily build of H15.5.
For Z-depth output you should be able to shade using ‘length(P - Eye)’, but I will need to confirm this. I will let you know shortly.
~M
Thank you mestela and mdavies for the support.
I really appreciate.
I've made the changes to the VR lens shader and attached the updated code here. The VR camera is a bit more involved, but the update will be available in the next daily build of Houdini 15.5. Please let us know if you have a chance to test out the new feature. Thank you.
~M
vrlens_sesi_v0001.zip (29.8 KB)
WOW, i just try, and it works like charm.
You just open the door of every planetariums ! Now they can render at 360*210, they like this ratio
For feedback:
An option for disable Stereo could be nice.
because when objects are too far, we don't need 2 renders.
But set the eye separation to 0 is ok too.
Hi Anodin,
There could be a toggle added to disable “Eye Separation” and “Eye To Neck Distance”, however I believe this is more suited to a mono latlong lens (as opposed to a VR lens). Though if you would find it useful I'll add this parameter.
~M
anodin
i speak too fast, planetarieums use a fisheye deformation.
But spherical to fisheye can be converted with Ae Skybox converter.
Do you know if it's in the plan to have a fisheye camera lens build in Mantra?
I see a lot of render have this feature (arnold, vray, maxwell, redshift…)
Hi Anodin,
It is possible to add a fisheye lens shader; if this would be of use I can set something up for you. I could send you the VEX shader directly for now, which would be included in Houdini 16.0.
~M
That will be amazing mdavies.
I am impressed by the quality for the Houdini forum.
Edited by anodin - July 22, 2016 12:07:09
