Hi Guys,
I'd like to import a spiders crowd simulation inside Unreal. Do you have any tip for a workflow to follow to make it readable by the engine?
Thx =]
Crowd System
5587 8 3- antoniocappiello_fx
- 24 posts
- 24 posts
I explain myself clearer, my question is if there's a way to make a crowd simulation inside Houdini and then export it baked as FBX inside Unreal. A solution I can think of is to export each agent as a single bone with its animation cached inside the FBX, but I don't know exactly how to achive that..
Maybe you guys have a better way to do it…?
Thank you
Thank you
- DASD
- 453 posts
I am far from an expert on the topic, but you could:
1. Export one full bone rig via FBX. (And import it into Unreal.)
2. (Batch) export the animation of each actor separately via FBX. (And import those as separate animations into Unreal.)
3. Create each actor in Unreal based on the same rig. Possibly randomize the looks of your actors in Unreal by hand or via blueprints.
4. Assign each animation to each actor. And make them animate.
At least, that's how I would approach it. I wouldnt be surprised if it could be achieved much easier. For example, you could try making a digital asset out of your baked sim and just importing it via Houdini Engine.
- 24 posts
- HenrikVilhelmBerglund
- 23 posts
- damian
- 402 posts
Alembic will be your best bet in the short to medium term, at least. Houdini Engine does not run at runtime because that would require shipping all of Houdini with your game. Even if you did change parameters in the Editor's sequencer, none of that will work once you compile and package your game at the moment.
- 24 posts
- DASD
- 453 posts
- grayOlorin
- 1799 posts
