Hi there,
I'm trying to export a simple geo as alembic sequence using ROP Alembic, but I'm unable to export more the 1 frame.
I'm rendering custom frame range from 1 to 10.
$HIP/output.$F4.abc
I would expect to see: output.1001.abc, output.1002.abc, output.1003.abc etc…
But I always get only “output.1001.abc”
I attached also a simple scene.
Am I missing something fundamental?
Export alembic sequence yields only first frame
7712 9 2- jizrik
- 6 posts
- Enivob
- 2625 posts
- jizrik
- 6 posts
Thanks,
Yes I'm aware of that alembic can contain the whole animation within one file. But that's not what I'm after.
I have a geometry which is different per frame and I would like to export each frame as a single file, but I'm unable to make it work with alembic ROP. I can do it easily with bgeo… is that some limitation?
- willh
- 134 posts
jizrik
Thanks,
There will be no limitations with bgeo that im aware off. Bgeo is the native format in houdini and should retain all attributes you embed in it.
It doesn't contain animation in a single file, but thats not what you are after anyway.
- anon_user_37409885
- 4189 posts
- btangonan
- 6 posts
- vusta
- 555 posts
- btangonan
- 6 posts
- vusta
- 555 posts
- vusta
- 555 posts
