I'm sure this is just something related to my system, possibly the fact that I have the latest Anaconda Python installed, but after installing H16 Indie today, I find that any operation that creates a node is taking between 40 seconds and four minutes to complete, during which it's showing progress messages like “Evaluating python”, “Run Hscript command”, “Updating Exports”, etc.
During this, there's no disk activity, memory usage is a mild 400MB, and even more oddly, CPU utilization is between 0 and 2%, with no network activity (or none large enough to register in Task Manager.
Gonna reboot…
Update: Reinstalling Nvidia drivers solved the problem.
H16 performance broken for me (fixed, was video driver)
5681 14 2- Zoot
- 15 posts
- anon_user_89151269
- 1755 posts
- Doudini
- 333 posts
- neil_math_comp
- 1743 posts
ZootThis is just a wild guess, but to check whether it's waiting for licensing over the network, can you check whether it's still slow if you switch to “local licensing”? https://www.sidefx.com/faq/apprentice-local-licensing/ [sidefx.com]
- Zoot
- 15 posts
Switched to localLicensing, no effect.
Every Torus is 45 seconds. Actually CPU utilization runs around 17% while trying to create a Torus.
Sometimes it seems to go out to lunch even more, to the point that the status line elapsed timer stops elapsing. But this is less common. 45 second Tori are very consistent.
Z.
Z.
- anon_user_37409885
- 4189 posts
- Zoot
- 15 posts
- malexander
- 5211 posts
- Zoot
- 15 posts
- neil_math_comp
- 1743 posts
Yikes! I'll post a link to this on the other thread that might be the same issue.
- malexander
- 5211 posts
- Zoot
- 15 posts
- Sheepnli
- clintonman
- 3 posts
I want to add my thanks too. Before downloading Houdini my Nvidia Experience thing said my drivers were up to date. Got Houdini and it ran horribly then found this thread. Checked Nvidia Experience again… update available, ok “click” and a few minutes later the install failed and NV Experience was gone. Final solution - went online to Nvidia drivers and found a newer driver, installed and all is good now. I was on 376.54 and the new driver is 378.66
- AndrewButtigieg
