Without changing the default settings of Makefile, I'm having the following error:
Building io/Compression.o because of Compression.cc
g++ -c -DOPENVDB_PRIVATE -pthread -O3 -DNDEBUG -I . -I .. -I /opt/hfs12.1.77/toolkit/include -I /opt/hfs12.1.77/toolkit/include -I /opt/hfs12.1.77/toolkit/include -fPIC -o io/Compression.o io/Compression.cc
io/Compression.cc:34:18: fatal error: zlib.h: No such file or directory
compilation terminated.
make: *** Error 1
OpenVDB
36211 24 6- FabianoBerlim
- 36 posts
- FabianoBerlim
- 36 posts
- Alejandro Echeverry
- 691 posts
Hi!!
Can someone give me a solution to compile the library without using the $LD_LIBRARY_PATH after compilation to use the libraries?
Because right now mantra stop working if I set that variable, it says that can't find the license server.
Thank you very much.
- zachlewis
- 45 posts
- bulettepain
