Hey!
I'm trying to use shelf tool, “Billowy Smoke”, applying on sphere. When I play the simulation on “obj” level, simulation updates and grows. But inside the “pyro_sim” node, simulation doesn't update at all. In “Houdini 15.5” it works perfectly. But in “Houdini 16” it doesn't work. What is the problem?
Simulation doesn't update inside "pyro_sim" node
2096 4 1-
- Alexander_Golubeff
- 3 posts
- Enivob
- 2637 posts
Hmm..I just tried your test and it works ok on my H16 system. I see smoke growing at both levels.
Try diving inside the simulation and locate the pyro node. Under the Guides tab then under Visualization make sure something is checked on, like Multi Field.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- 3 posts
- Enivob
- 2637 posts
- 3 posts
