I'm following this tutorial from Steven Knipping: https://vimeo.com/162636675 [vimeo.com]
At around 28:15 in the tutorial, he has you add in a Smoke Object node inside a DOP Network and attache it to the OUTPUT node inside the DOP Network.
When he does it, he receives no errors. However, when I attempt that, I get an error.
“set_icluster”
“Not enough sources specified.”
When I dive into the Smoke Object node, I noticed another node that's not connected to anything called set_icluster, which is a Modify Data node.
(UPDATE: Maybe this is a SideFX bug. I allowed the Smoke Object mode to be modified and connected the set_icluster node to the Smoke Configure Object node and the error went away. I'm on Version 15.0.244.16 (15.0.244.16) of Apprentice, so maybe I need to try it on a later version.)
Anyone have any ideas what's going on?
Smoke Object giving me an error.
4270 4 1- reelinspirations
- 177 posts
- Bartimaeuse
- 3 posts
- urbanlife
- 3 posts
- urbanlife
- 3 posts
- Artisanaltv
I was also following the same tutorial. I also hit the same problem at 28:15. I was using Houdini Indie 15.5.632, as that's the last version that is currently supported by C4D to work with the Houdini to C4D pipeline.
When I switched to Houdini Indie 16.0.584 and retraced my steps, the smoke object now works.
Not sure what the problem was in 15, so I'm not sure I so much “solved” the problem as sidestepped it.
