sorting random (noisy) points that clearly make a shape
   3778   4   1
I have a bunch of randomized points, and in this example they form a circular shape, although they could easily be a noisy line. Even though I can clearly see the shape in the noise, I haven't figured out how to order the points so I can add a line across them.
My attempt was to split the circle into 2 halves, and then sort along the z-axis. Although it mostly works, it can still run into problems as shown in the image.
random_point_sort.hipnc (86.2 KB)
K, I have a working solution. Still interested in what solutions other people have.
random_point_sort_2.hipnc (71.1 KB)
Uvtexture node set to cylindrical Y and then sort node set to attribute $MAPU .
A point VOP containing frompolar node.
An attribwrangle converting cartesian to polar coordinates using sin() and cos() .
Konstantin Magnus
or:
(atan2(y,x)+PI)/(2.0*PI)
If you have knowledge of the spline, which the points are following you can create an attribute (with xyzdist()) to get the u-value for each point to sort them with it . This works quite ok even for roughly approached splines. But if you have no information to create one, I think some heuristic solutions for the “travelling salesman problem” should work aswell but I don't have much experience in this area.
random_point_sort_Curve.hipnc (93.3 KB)
