UVTexture - Cylindrical perfect mapping
7349 18 5-
- bhb
- 67 posts
- Konstantin Magnus
- 698 posts
For boxes and rectangular surfaces you could just use cubic mapping:
http://forums.odforce.net/topic/18451-uv-cubic-map-procedurally/ [forums.odforce.net]
- bhb
- 67 posts
- Konstantin Magnus
- 698 posts
I´d still say use cubic mapping.
Edited by Konstantin Magnus - Sept. 14, 2017 02:17:54
- bhb
- 67 posts
That image you posted here looks fine.
Yesterday, I tried the vertex wrangle you posted, and didnt worked for me.
The -X, X primitives UVs are rotated 90º down.
Attribute Wrangle(Vertices):
vector bbox = relbbox(0, @P);
vector side = sign(@N);
vector nml = abs(@N);
vector size = getbbox_size(0);
vector ratio = size / max(size);
vector scale = bbox * ratio;
//if (nml.x == max(nml)) { @uv = set(-scale.z * side.x, scale.z, 0); }
if (nml.x == max(nml)) { @uv = set(scale.y * side.x, scale.z, 0); }
else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, scale.z, 0); @uv.y += 1; }
else { @uv = set(scale.x * side.z, scale.y, 0); @uv.y += 2; }
@uv *= 0.3333;
@uv.x += 0.5;
- Konstantin Magnus
- 698 posts
You probably have to switch two vector components in the code or so. I will look into it over the weekend.
- Konstantin Magnus
- 698 posts
if (nml.x == max(nml)) { @uv = set(-scale.z, scale.y * side.x, 0); }
else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, -scale.z, 0); @uv.y += 1; }
@uv *= 0.3333;
@uv.x += 0.5;
- bhb
- 67 posts
- Konstantin Magnus
- 698 posts
What do you mean? The script is just doing cubic UV mapping. All it does is dividing UV islands by the primitives main orientation. And its mapping straight from the sides.
Maybe append a UVlayout node, but it´s a bit hard to tell what you are after.
Edited by Konstantin Magnus - Oct. 21, 2017 08:45:08
- bhb
- 67 posts
- matthias_k
- 483 posts
- bhb
- 67 posts
- matthias_k
- 483 posts
Hi, that's right, but you can manually remove the cuts.
I made them to avoid distortions.
Maybe then UV edit/move the points.
If I'm right, then you'll need for perfect fit,
a volume based shader or real geometry.
Edited by matthias_k - Oct. 22, 2017 11:42:55
- Konstantin Magnus
- 698 posts
If you want all projections to line up, you have got to simplify the code a little:
vector bbox = relbbox(0, @P); vector side = sign(@N); vector nml = abs(@N); vector size = getbbox_size(0); vector ratio = size / max(size); vector scale = bbox * ratio; if (nml.x == max(nml)) { @uv = set(-scale.z, scale.y * side.x, 0); } else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, -scale.z, 0); } else { @uv = set(scale.x * side.z, scale.y, 0); } @uv = abs(@uv);
- bhb
- 67 posts
- matthias_k
- 483 posts
- bhb
- 67 posts
That is Mathias, the code supported by Konstantin is very good if we want to paint after outside in Mari or Substance Painter. There are little seams that are appreciated when the camera is near them.
I tried another way using node UVProject (Cylindrical). But same as UVTexture, when the proportions of the chimney changes the texture 1:1 ratio distorses.
For the “real geomtry projected” I will try soon the file you uploaded. Thanks.
Edited by bhb - Oct. 22, 2017 15:03:34
- matthias_k
- 483 posts
If you need it only on the sides, with small convex shape…
then maybe define first UVs, then deform.
This should give a perfect match, if the texture is seamless.
Ups, vertical line should have same point count like the lattice deformer (4)
Edited by matthias_k - Oct. 22, 2017 15:38:09
- matthias_k
- 483 posts
Better…
to change the width, depth, modify the “curve1”, the multiplier for the UVs
is:
vertical the height of the “line1”
horizontal the point count of “curve1”
with this 2 values in mind you can easilly add a UV transform and set right multiplier.
is:
Edited by matthias_k - Oct. 22, 2017 15:50:09
