popsolver1 node causing particles to become black
11545 9 0- trevorscotthileman
- Enivob
- 2629 posts
It may be related to your graphics hardware. Go ahead and put your machine specs in your signature.
Also press the D-KEY while your mouse is over the 3D window to bring up the display options. Make sure you have HDR rendering under the Effects tab enabled.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- ChrisSchofield
trevorscotthileman
I am running tutorials through digital tutors. I selected the fire extinguisher and used a source particle and it turns into a block box. When I play it back the particles are just black and not separate from each other. Why is the pop solver node causing this to happen?
Trevor, did you find a solution to this issue? I'm experiencing exactly the same issue. I'm a total Houdini beginner (second tutorial). I did notice that in ‘Wireframe’ view, the particles are there, so I'm guessing it's something to do with how they're being rendered in my viewport?
I've checked my drivers are up to date etc. Any input would be appreciated!
System specs:
GeForce GTX 980Ti
Intel(R) Xeon(R) E5-2670 v3 @2.30GHz
16 GB RAM
Windows 10 Pro
Chris
- Kev Ryan
- 4 posts
While this may already have been figured out, I ran into this issue today and managed to fix it for myself. All I had to do was hit D (while hovering over viewport) and on the particles section of the geometry tab, make sure that display sprites was ticked off.
Oddly enough it only occurred when I plugged in a mocapbiped via a file merge into a geometry particle set-up, as opposed to a sphere.
- XanaduArt
- 4 posts
Kev RyanOh man, very appreciated that you share the solution with us. Thank you very much.
Have a nice day bro.
- 8043 posts
- ikakovsky
ChrisSchofieldYeah dude <3 that all, love ya ma' men.trevorscotthileman
System specs:
GeForce GTX 980Ti
16 GB RAM
Windows 10 Pro
Chris
- Heks12
- 10 posts
- mestela
- 1803 posts
If you're using any of the test geometry as a base (pig head, rubber toy, tommy), they have a shop_materialpath defined. This is inherited by the particles, where it's assumed that the material must be a sprite shader. It's not. As such, it renders black.
Most of the test geometry nodes have an ‘add shader’ toggle, turn it off.
-matt
-matt
- MilanB
- 159 posts
But what if i want to have texture of the instanced objects? Is good workflow to put an assemble sop to pack after my copytopints through which i have the objects instanced on the popnet, and i add a material sop after after unpacking?
Something like this bellow?
Edited by MilanB - Sept. 21, 2020 04:00:27
