point wrangle - data between iterations?
   Views 2432   Replies 3   Subscribers 0
hello.
I would like to share and change data between point wrangle iterations.
is it possible?
ex: array which is filled in every iteration
thanks
you'll need to have your wrangle either in For loop (feedback) or Solver SOP
Thank you Tomas.
Unfortunately I need to have the data exactly inside the wrangler. As example:
Array which is collecting @P.y value from every point and checking is the same value is already in array.
then you can use Detail Wrangle and for loop inside, looping over all points
float @uniquePyArray[];
int npt = npoints(0);
for(int pt=0;pt<npt;pt++) {
    vector P = point(0, "P", pt);
    if (find(@uniquePyArray, P.y) < 0) {
        append(@uniquePyArray, P.y);
Edited by tamte - Oct. 28, 2017 13:54:36
