Connecting a building with a surface
   2062   2   0
Hi Guys,
I modeled a box that simulates a little building, and I want to connect it with a surface (grid) for simulating an earthquake. What is the best way to achieve it?
I searched through constraint networks (docs houdini), but I haven't found the proper tutorial for constraints applied for a building.
Thanks for your advices,
If you are only wanting to connect the box to a grid then you can parent the box to the grid at the top OBJ level.
Reel Inpsirations
Houdini Work in Progress [vimeo.com]
Hi Reelinspiration,
I appreciate your advice. But I connected the building (box) at DOP level with a net of constraints and seems that it works.
Thanks for your answer,
