I'd like to apply some wind force to a flower.
I've tried to use the popGrains node without much success
Have a look at the reference image, my goals are simple:
1) A wind force should bend and move the flower.
2)The movement of the whole flower should be influenced also by the weight/size of the ovary (green sphere).
3) the branches/petals attached to the ovary should move and bend accordingly
So far I sort of managed to move and bend the main stem inside a popnet with popGrains and attach the ovary-sphere to the end point of the stem. I cheated a bit to simulate the weight of the sphere, by dealing down the weight of the end point of the stem.
To simulate the branches/petals attached to the ovary, I tried to reproduce this setup found in Grain Solver for wires [www.tokeru.com] (file by Matt Estelahere [www.tokeru.com] ).
I got crazy results when I tried to use the @targetP attribute to drive the stiffness of my wires. I guess there is some conflict going on. Also probably it's not the way to go…
Anybody want to have a look at the attached project file?
popGrains for flowers bent by the wind. Problem..
1953 2 1- Andr1
- 118 posts
- 8598 posts
- Andr1
- 118 posts
Hey Tomas thanks for the tip,
I tried the wire solver way and got better results indeed.
I used this trick [ihoudini.blogspot.de] to simulate the reciprocal connection between the wire and the attached sphere.
It reads internal force (@finternal) of the attach point on the wire, and apply it to the sphere with a “point force” node.
Problem:
How to do the same with multiple wires/spheres?
My idea was to use a Sop Solver node and read the @finternal and @P for every attach point and apply it to their relative sphere.
Somehow I should find a way to simulate a point force for ever attach point on the spheres. (But I don't really know how to do it).
Anyway, I'm already stuck before even trying: when I connect the Sop Solver (along with rbd solver) to a multiple, spheres go upwards.
I attached the hip file, in case you or anybody else is kind enough to have a look..
Problem:
Edited by Andr1 - Feb. 24, 2018 04:10:20
