It it possible to run two Documents/Houdini 16.5 on windows.
   Views 2243   Replies 2   Subscribers 1
Hi
I want to run two 16.5 setups on my one pc. So I would have two Houdini documents folder which houses the ENV and presets etc..
Is it possible to direct a selected Houdini.exe to a particular folder so I can experiment with different setups…
Perhaps you can…but am not aware of how too.
Maybe what you might have to do is employ start up scripts to test different settings and/or have different *.env files in the same directory to switch between.
BabaJ
That did cross my mind but I'm hoping there is a simpler way .
