Copy geometry other object by UVs
6690 6 1-
- sbobcat
- 41 posts
how could I copy geometry like this checker pattern to another object in this case the good old pighead by UVs? Similar how you would apply a texture. But instead of 2D image you would copy this “checker” 3d geometry to the pighead. And you would get the checker pattern in shape of the pighead, in 3D.
I think in this video by MIXTraining, half of the job is done. Now just to copy the geo not quads but the whole surface based on UVs
https://www.youtube.com/watch?v=Z3ZkGoa3kZE [www.youtube.com]
thank you
thank you
- 9111 posts
- Konstantin Magnus
- 697 posts
There is a VEX function for transferring attributes such as position from one object to another based on their UVs:
This method does not consider UV islands yet. However after setting a connectivity SOP to UVs, you can filter out stretched primitives by asking whether they come from different UV islands.
v@P = uvsample(1, 'P', 'uv', @uv);
Edited by Konstantin Magnus - Jan. 26, 2019 03:55:26
- sbobcat
- 41 posts
Thank you Konstantin, uvsample was just the command I was looking for! But I used it a bit differently. First I took some code from GameDev tools and flattened the template geo in world space by UVs. Then by using boolean I cut out the parts of the pattern I didn't needed and transfered UVs from the template. Then by using uvsample I matched the pattern to surface. Its much slower since it needs to boolean the pattern first but gives me more of a result I was hoping for.
Thank you Tamte, tried that detailed mesh tool but it didn't quite work for me.
- Konstantin Magnus
- 697 posts
Well done! I just simplified it a bit.
- sbobcat
- 41 posts
- oxidave
Hello all,
I am trying something similar. Actually, Konstantin, it's from your video here:
https://www.youtube.com/watch?v=6y9LVfM6N70 [www.youtube.com]
I am using the uvlayout node to pack geo that I would then like to place back onto the input geo. However it flattens the meshes.
My attribute wrangle is this:
v@P = uvsample(1, 'P', 'uv', @P);
Thanks in advance!
Thanks in advance!
