vellum and angular velocity
   4246   2   1
I have been trying to set an angular velocity (w) to an object but vellum does not recognize it.
I used a wrangler node just before to plug my geometry into the vellum but it does not works.
How can I do that?
thanks you.
Gerardo Castellanos
www.gerardocastellanos.com
I finally got to put my hands on Vellum and I also found that @w doesn't seem to be taken into the sim as it used to be. Any clue on how to add initial angular velocity now ? Did that change ?
Chris
I supous like vellum works with points, has no sense angular velocity, because @w would spin each point on itself.
My solution it's a point wrangle, and set linear velocity (@v) for each point independently. In this way, each point it's simulated with a velocity equivalent to @w, and this result like the object has angular velocity.
