Connect adjacent primitives
   2654   6   1
I'm trying to connect only adjacent primitives.
But,I don't know how to do.
If you have idea ,could you tell me?
Edited by kazurati - April 12, 2019 23:34:24
What do you mean by connect?
Turn all the prims into a single one?
And for what purpose.
You could use a fuse sop, is that what you want?
Otherwise post a hip with description of what you want to do.
Divide SOP > ‘Remove shared edges’.
Konstantin Magnus
Thanks for answer.
This is exactly what I wanted to do.
Thank you both.
I tried DIvide node.
But the result is a crazy geometry.
Why is this?
You can use any method, please tell me the solution.
I set the path of the image named “number-14-gray” here.
HowRemoveSharedEdges.hipnc (167.4 KB)
You would usually use the trace SOP for this:
http://www.sidefx.com/docs/houdini/nodes/sop/trace.html [www.sidefx.com]
Konstantin Magnus
I tried it,but it is very slow
