Hi all,
As soon as I assemble a Voronoi fractured object into packed geometry the wire shading disappears. Both in Flat Wire Shaded as well as in Smooth Wire Shaded I just see a shaded object without a wireframe? When I set the visualisation to either Wireframe of Wireframe Ghost eveything looks fine though.
On top of that, I can't get the Voronoi fractures to be colorized separate anymore (the ‘Visualize Pieces’ option has been removed).
I can't get it to work in the new visualize geometry node.
What am I missing here?
Houdini 17: Visualize Voronoi Fracture
9892 7 4-
- Farmeadow
- 30 posts
- Bergerac
- 12 posts
Hey,
yeah i found this confusing at first too (the visualizer not being there)
I think the new workflow is to click on the new visualizer button next to the name prefix, however it just throws errors when i try to use this (i think its broken as it doesnt work anywhere)
I got the pieces to show up by hitting x to add a new visualize node, then setting it to:
- color
- random from attr
- primitive
- selecting ‘name’ from the attr dropdown
And by making sure viewport visualization is on
Hope that helps!
C
- color
- random from attr
- primitive
Hope that helps!
C
- Rendering_no
- 11 posts
- vicvvsh
- 58 posts
- buki
- 1773 posts
hi!
- as of H17, if you hit “D” in the viewport, go to Geometry tab, on the right you will see an option “Wire over packed geo”
- wooyangkim
- 14 posts
- Jimmy_Fan
- 21 posts
- ddankhazi
- 8 posts
