Ocean foam displacement
   2752   3   1
I'm getting a very weird render with the default large ocean shelf tool.
Any advice ?
Another try:
Hi! have you ever found a solution to this?
A-OC
Another try:
it seem like you have double displacement where your displace ocean mesh from spectra map then where there is foam it become also additional layer into the final displacement. You need to mask out only where need to add displacement, I guess so
