Procedural Wolrd Generator
8704 11 3- samuelbrunner
- 38 posts
What does it do ?
Terrain
Layers
Roads
Place houses in villages
Place buildings in towns
Level the terrain under houses and buildings
Place Trees
Place Rocks
Hda for Unreal : TerrainV4.7.hdalc (See attachments at the bottom of this post)
Source for Houdini : LandscapeV4.7.hiplc (See attachments at the bottom of this post)
Terrain Auto-Material : https://gofile.io/?c=VterOq [gofile.io] // Copy it in /Content/HoudiniEngine using explorer ( should look like Content/HoudiniEngine/Lanscape_Material.uasset)
Texture Pack : ( allready in terrain auto-material .zip)https://gofile.io/?c=p6QokK [gofile.io]
My Discord: https://discord.gg/QkM4MF9 [discord.gg]
How to Use it ?
1 - Download Houdini [www.sidefx.com]
2 - Don't forget to check unreal on the install process [support.borndigital.co.jp]
3 - Import the hda in Unreal
4 - Drag n Drop the hda in the scene
5 - You should see the hda cooking
Parameters
Once you finished importing all the stuffs ( see quick tutorial in the next post ) you can start changing parameters.
- Try changing the offset parameter, it will offset the noise and basically you get a new terrain
Result
Once you happy with the terrain try changing the resolution to 127, 253, 505, 1009, 2017, 4033, 8129 ( currently there is a bug and the terrain is locked to 1009 )
Tips
- Disable this if you don't wan't to auto-cook each time you change a parameter, you will have to manually recook the asset ( select the terrain, right click, recook )
What does it do ?
Terrain
Layers
Roads
Place Trees
Place Rocks
How to Use it ?
Parameters
Result
Tips
Edited by samuelbrunner - Aug. 19, 2019 07:07:46
- samuelbrunner
- 38 posts
Quick Start
1. Import the .hda, then drop it on the scene, the hda will cook
2. Create landscape material:
2.1 Copy in explorer the landscape material into to your project folder
2.2 Open landscape material and reassign textures ( Be sure to assign normals too ! )
3. Applying the material on the terrain :
Select your terrain
Right click on your terrain material, copy reference
Paste it on the “Your terrain path” parameter
You should see the material on the terrain
In case there is a problem with terrain layers :
- Delete your terrain
- Clean Houdini temp folder
- Drop your hda back on the scene
- reasign terrain material
4 Placing trees and buildings
- Select your terrain
- Find houdini instanced inputs ( Detail panel )
- Drag your trees model on green cubes
- Drag your building model in pink cubes
- Drag your houses on yellow cubes
- Drag medium buidlings on orange cubes
- Drag rocks on red cubes
5 Add variation
- If you wan't to make some variation with meshs, click the + button, and drop the other model
Select your terrain
5 Add variation
Edited by samuelbrunner - Aug. 17, 2019 09:30:51
- RetroRocketGames
- samuelbrunner
- 38 posts
- rhamm1320
- 8 posts
- samuelbrunner
- 38 posts
Hi, thx, roads are very bad, if i could learn how to code this would be much better, like a good road pathinfing, better terracing for road and building, also procedural rivers could be great.
Yesterday i added towns with buildings, and made the terrain look better.
For now i removed the parametter because of a bug with them.
- John31
- 72 posts
- samuelbrunner
- 38 posts
- HatmanAlchemy
- 3 posts
- samuelbrunner
- 38 posts
- caijitimon
- steezylabreezy
