Skeleton curve implementation based on VDB medial axis
   21071   26   13
@jason_iversen
Honestly, I have no idea. The weight map should look like a thickness/density map. If you combine that with skeleton curve partitioning(limb partitioning) you might get some localized effect similar to the biharmonic weighting. I don't know..
Thanks! I'll take a look at merging your newest changes in as well!
Luiz Kruel
Senior Technical Artist
Big thanks for the knowledge you shared here!
rpopovici This is incredibly useful, thank you for sharing and apologies for jumping into this not so recent thread.
lkruel
lkruel, when you say merge, does that mean that this (or parts of it) will make its way into houdini?
Lyubomir, thanks!
It is already merged into sidefx labs project(https://github.com/sideeffects/SideFXLabs). Thus, not sure if it is the latest version..
Found it, thanks again!
I naturally followed the breadcrumbs from the houdinigubbins post to this one...and well...WOW. This is remarkable. Thanks for sharing
