I am looking at creating a sin random value to a sign wave inside a bend op, with primary axis set to X
using sin ($FF *3 )*12
This works fine , now is there a way to also have it moving in Y at the same time ? coupled with a rand expression , so when I use the copy stamp all my stems will be randomly moving in X and Y. I know the rand (value ) and I know a sin wave works between +1 and -1 so really I am just looking for a rand value that would off set the ($FF * ) as a starting point. If anyone could give me some pointers I would be greatfull.
Rob
random offset for Sin waves
11806 4 0-
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
An update ….
what I have done is to get a correct motion is to use a transform SOP and create a Sin expression on the X axis and the Z axis , this works much better than the bend SOP. this way I can have the sin wave work in both X and Y.
Now I would like to use stamp function in the copy SOP ,to randomly apply this sin wave to all my copies created .
I have tried sin($FF*3)*10) it works fine in the Copy sop (stamp) but all the copies move togeather. I have also tried sin($FF*(rand(123)))*10) , again it worked but all the copies get the same motion from the sin wave.
cheers R
cheers R
Gone fishing
- AdamJ
- 268 posts
- circusmonkey
- 2624 posts
adam Ive tried your solution but I cannot get it to work , do you have a simple file I could look at , grid , sphere , copy stamp ?.
I was thinking along the lines of just have the 1 sin wave then somehow offsetting when and where the the objects start moving along the sin wave maybe using there object ID to drive this.
A slight update using the copy SOP stamp with this expression in the X or Y values
varible1 sin(($F*2) + ($PT*2))
varible2 sin(($F*2)*3 + ($PT*5))
I get a nice movement still a bit to uniform , but at least it works ! would it be possible to add some noise into these expressions using noise(x,y,z) certainly interested in thoughts
R
R
Gone fishing
- rjpieke
- 65 posts
circusmonkey
You could try modifying both the phase and frequency and use rand() instead of noise()
So, for example, something like:
sin( $F*(2+0.5*rand($PT+0.1)) + ($PI*rand($PT+0.2)) )
Cheers!
