I am new to houdini so I will say what I am trying to do first incase there is a much easier way to go about it.
My goal is take a stack of black and white bitmaps and use them to make a voxel model, each one acting as a layer of the model.
my plan was to use a grid into a copy node and mask off points on the grid using the bitmaps.But I cant figure out how to get it to work or similar examples.
then figure out how to set a for loop for the folder of images, which is probably more challenging than I am expecting as well.
any help or advise would be greatly appreciated thank you!
help using bitmaps to generate models
4077 5 1-
- breht
- 11 posts
- Konstantin Magnus
- 719 posts
I would first use a tiles-node in COPs to create a sprite sheet of your images. then attribfrommap transfers the pixels to your grids.
- Olaf Finkbeiner
- 323 posts
Hi Breht,
maybe you should first learn houdini before trying something this specific.
If you are into volumes and want to learn about volumes you will find a lot of tutorials etc.
http://www.tokeru.com/cgwiki/index.php?title=HoudiniVolumes [tokeru.com]
Have Fun
Olaf
Have Fun
Olaf
- breht
- 11 posts
- goldfarb
- 3465 posts
you might have fun reading this:
http://www.minecraftforum.net/forums/mapping-and-modding/minecraft-tools/1262072-houdini-to-minecraft [minecraftforum.net]
- Sahak Sahakian
- 10 posts
goldfarbThat article looks super. However it refers to a demoPackage.zip file that is no longer available. If anyone has acess to this from before, or have another reference please share
http://www.minecraftforum.net/forums/mapping-and-modding/minecraft-tools/1262072-houdini-to-minecraft [www.minecraftforum.net]
