Hi
It is a re-occurring question:
How can I bake out the results of a motion FX applied on top of a keyframed channel (lag or spring or any which)?
In previous Houdini versions I figured out this could be done through the ‘fit panel’-icon, visible in the Animation Editor. Now that button has disappeared and I am at a loss..
Standard ‘bake keyframes’-commands seem to do nothing.
Thank you
How to bake motion FX to keyframes?
3108 2 0-
- mackerBaehr
- 86 posts
- brianBurke
- 192 posts
if you jump down into your motionfx chop network, you can find the chop that's exporting back to your animated parameters. its visible by having the orange export flag enabled, on the left side of the chop node. to bake this chop to keyframes, left click on it and navigate to ‘save’. from the ‘save’ submenu, you can select ‘edit data channels’. this will pop up the fit to keyframes dialog. if you set the fitting tolerance to 0 from the ‘fit panel’ and click ‘copy to export destination’, you will bake your motionfx to keyframes.
the export chop has the orange flag
hope this helps!
b
hope this helps!
b
- mackerBaehr
- 86 posts
