Will Polyexpand2d and some NURBS SOP be compilable in Houdini 18?
   Views 3205   Replies 5   Subscribers 1
I find Polyexpand2d SOP is so important in procedural modeling, it can generate straight skeleton, simple road, hip roof and so on.
And some NURBS SOP like fit / refine are also necessary for procedural modeling.
I think the official progress of making SOP compilable is a bit slow.
Edited by zengchen - Sept. 21, 2019 02:00:37
My Youtube Channel [www.youtube.com]
Add the Poly Extrude node, please.
@zengchen01 can you explain how do you use it to generate simple roads, or suggest any specific tutorial you follow.
Trying to do this using OSM data, but with no luck (a beginner anyway).
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
davide445
The road I generate by Polyexpand2d SOP is quite simple.
I think this road tutorial is more useful.Dokai Tutorial [vimeo.com]
Edited by zengchen - Oct. 11, 2019 20:41:14
zengchen01
I've seen this tutorial but seems really complex for a beginner like me.
Simple roads are fine if also the setup is simple :-).
Can you point me out in the right direction.
Edited by davide445 - Oct. 12, 2019 06:22:13
davide445
Dokai's tut seems a bit complex, but honestly it still has a lot to improve for the Game output…
As for the polyexpand2d SOP, when create simple road, it can not generate UVs.
And I do not use polyexpand2d SOP to generate streets based on the OSM data, so I think you wouldn't get any more help from me…
Here is an simple example about polyexpand2d SOP itself, hope it works for you.
Edited by zengchen - Oct. 13, 2019 03:08:32
polyexpand2d.hipnc (69.0 KB)
