Group node bounding object doesnt pick my object
3302 7 1- Nusmad
- 8 posts
Hellow guys!
I'm learning houdini by one of the applied houdini tutorials, he show that enabling bounding object the points that the glue created, will be isolated for future removal, i dont knwo wants happening. He is using houdini 15.5 so maybe its something related with the version but i looking everywhere and nothing helps. Hope you can!
This is the applied houdini screen:
- goldfarb
- 3459 posts
- Nusmad
- 8 posts
- goldfarb
- 3459 posts
- Nusmad
- 8 posts
- goldfarb
- 3459 posts
- Nusmad
- 8 posts
goldfarbSeems that it doesnt work in my version, cause I tried to turn off the base group and clearing the 1 and that doesnt work either. I downloaded the project that you attached and no points inside too I will try to update houdini
since this is a sim it looks like the get_metaball merge is only bringing in any geometry from frame 3 on…
I just cleared out the 1 from the base group and turned OFF Enable
and it seems to work just fine,Image Not Found
- Nusmad
- 8 posts
NusmadI have updated my houdini version and definitely that was the solution, so maybe the version 17.0.352 has a bug with that node.goldfarbSeems that it doesnt work in my version, cause I tried to turn off the base group and clearing the 1 and that doesnt work either. I downloaded the project that you attached and no points inside too I will try to update houdini
Thanks so much for your time and your help, I apreciated it!
