Houdini viewport/UI problem
8138 7 3- cullenhassel
- 4 posts
Curious if anyone has had this problem before? I have contacted Side FX about this a couple times and the best answer I could get was to use Qt4 builds up until now I guess they aren't making Qt4 builds for H17 and I am really wanting to test it out. I've tried changing the UI size with the preferences and inside the houdini.env file and have tried refreshing my preferences completely and haven't found any luck or answer as to why this occurs.
- quentinmourier
- flo_w1
- 4 posts
- mariasola
- flo_w1
- 4 posts
Well, I'm having the same issues and couldn't resolve it either, but as far as I can tell it seems to be Intel GPU and driver related. Some gyu over at the Intel forums was able to fix it by not using the latest driver but some version around 25.20.xxx.xxxx. I don't know what your system specs are, but if everything was working for you till this morning you should be able to restore your system to a previous state, or install older drivers.
- Found another reference to this problem in the dell forums - if you're using one of their XPS laptops with intel graphics (HD 630 i.e.) you could try this driver: “25.20.100.6583, A06”
Edited by flo_w1 - Dec. 10, 2019 15:09:22
- keepersdungeon
- orly.junior
- megiddgit
- 7 posts
