Set external script editor not working
   Views 13533   Replies 15   Subscribers 6
H 17.5.391 (but doesn't work for me in earlier builds as well)
this seems to be a function related to the game dev toolset? Not sure.
Can anybody help me with this (plz see description below)?
Marc
Description:
When I use ‘Preferences/Set External Editor’ to point to a editor like notepad++ or sublime, I get the message that the editor is successfully set.
1. But, when I hit the ‘External Editor’-button in a opened expression window, Houdini will still open notepad.exe.
2. And when I want to open the external editor directly from the parameter field via right-click -> ‘Expression/Edit in External Editor’, the following message appears:
'float' object has no attribute ‘encode’
File “<stdin>”, line 5, in <module>
File “C:/Users/defsh/AppData/Roaming/SideFX/GameDevToolset/17.5/1.196/scripts/python\houdini_external_editor.py”, line 253, in add_watcher
data = str(parm.eval().encode(“utf-8”))
AttributeError: ‘float’ object has no attribute ‘encode’
Edited by bollili - Nov. 18, 2019 08:42:54
I did just update the game dev tools to build 220. Same problem persists.
Forgot to mention… I'm on Windows 10.
As always it's required to edit houdini.env to connect something external to Houdini and make it work. See the video:
Hey Faitel,
thanks to you, I got it working.
So this function (see screenshot) seems to be just broken.
Bumping this old thread. How did you resolve this in the end bollili? I have been able to set the VISUAL environment variable but it seems that there is still something broken relating to this in SideFX labs.
Edited by jlrvfx - May 24, 2020 13:09:51
I found I was able to resolve this by removing SideFX Labs, quitting Houdini, updating the .env, then a fresh install of SideFX Labs R416, then resetting the preference again through Edit > Preferences > Set External Text Editor.
Hey there,
almost two years later, I encounter a problem with the external script editor.
I managed to pass in the external script editor exe like molder mentioned and alt+e opens the external editor like expected. but the pipe from the temp file to the expression field seems broken, since saving the file will not update the code in the node. right-clicking edit in external editor works fine though.
any idea, why this might be?
The solution is to add -w as a launch argument to the end of the environment variable value. This waits for the process to close which houdini requires according to support, and keeps the item loaded in a single thread.
EDITOR = "C:/Users/XXXX/AppData/Local/Programs/Microsoft VS Code/Code.exe -w"
Edited by Andrew Graham - May 27, 2022 20:45:08
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
if you install the sidefx labs it would be solved
Gerardo Castellanos
www.gerardocastellanos.com
molder
EDITOR = “C:/Users/XXXX/AppData/Local/Programs/Microsoft VS Code/Code.exe”
Thank you!
Set external editor crashes Houdini after file browser pops up briefly. Just setting it in the houdini.env file worked, thank you.
I managed to use VSCode as external editor for python scripting but I'm experiencing few issues:
  1. The hotkey ALT+E does not work because it launches the internal Houdini editor. To properly launch VSCode, I must right-click (RMB) on the Python Code parameter, select 'Expression', and then click on "Edit in External Editor."
  2. When editing a Python SOP, I must include "import hou" in the code to enable autocompletion in VSCode, which is redundant for a Python Sop.
  3. Additionally, autocompletion is not instantly available; there is a significant delay of at least 15 seconds before it becomes accessible in VSCode.
Regarding 2, I tried to add the following line in the settings.json of VSCode, but it didn't work:
    "python.autoComplete.extraPaths": [
        "C:\\Program Files\\Side Effects Software\\Houdini 19.5.569\\houdini\\python3.9libs"
I managed to make the hotkey launch an external editor. I have to:
- hover the mouse over the title of the parameter (as in the attached picture)
- also, the text cursor can't be active in that parameter
Did anyone manage to launch an external editor, while the cursor is active in the parameter?
Screenshot 2024-04-08 090844.png (27.1 KB)
I am having the same issue even in H20.5, everytime you open the external editor you need to close the file in VSCode to prevent Houdini from crash!
jomaro
did you use -w like I suggested?
Andrew Graham
jomaro
Yes I did, it looks like it's the normal behavior, you need to close the file in VSCode so Houdini can pick it up!
