how to make points created by "scatter" evenly dis
   17553   12   3
may i ask how to make points created by “scatter” evenly distributed across a irregular surface?
and also, how to make all the scatter points located within the surface?
- Ji
cookie2.hipnc (57.2 KB)
Screen Shot 2012-06-16 at 3.42.13 PM.png (97.9 KB)
Check this blog posting by Schnelli:
http://schnellhammer.net/blog/2010/06/uniform-scattering-in-houdini/ [schnellhammer.net]
Martin Winkler
money man at Alarmstart Germany
thanks, protozoan!
May i ask how to get the triangulation based on the evenly distributed points created as shown in the link you posted?
- Ji
points.hipnc (62.6 KB)
Screen Shot 2012-06-16 at 4.38.36 PM.png (115.6 KB)
csUniformScatter.otl (17.3 KB)
Here's another brute force way that brickers the geometry with the Divide SOP, over-scatters the points and then uses two Fuse SOPs to first snap and then cull the overlaps.
uniform_scatter_of_points_with_fuse.hipnc (67.7 KB)
thanks a lot, Jeff!
If it's not too troublesome, can you advise on how to make the 2D triangulation happens only within the boundary as defined by the points?
- Ji
oat
.. how to make the 2D triangulation happens only within the boundary as defined by the points?
drop a ClothRefine SOP between the Cookie and Scatter .
// it ‘ sleeps ’ inside the Cloth submenu //
thanks, Zarti! your suggestion can create similar results.
What I want to know is how to get the triangulation based on the points we get from Jeff's approach, i.e. how to get rid of the surfaces highlighted below in yellow boundary as generated by the Triangulation 2D SOP…
Advice is appreciate!
- Ji
Screen Shot 2012-06-16 at 10.45.05_c PM.png (75.7 KB)
pardon the delay . problems with internet from here
in the above post i just replied to the question ,
which i didnt connected it with the hip-s being shared to that point .
anyway ..
, i made few additions to the file you posted on post #3 ,
where you already solved the point 's distribution .
added few comments too about different small issues ( hopefully ) .
hope that helps ..
pointz_183.hipnc (77.7 KB)
thank you very much for your advice, Zarti!
will take some time to digest ur approach.
- Ji
attached you can find a scene how I made the samples shown on my blog.
I hope this helps.
Triangulate2D.hipnc (73.8 KB)
Dear schnelli, thank you very much! - Ji
plz give me link for download csuniform scatter.
karanpruthi253
Hi, this is no longer necessary. Houdini's scatter node already contains this feature.
