how can i import a fbx without the fbx window??? and i ask this because in a small resolutions the window doesnt fit the screen and you cant click the accept button!! and the window isnt resizable, i wonder why they dont make this window resizable, do you know whats the logic behind this?? so the question is how to import a fbx without this window, i cant click accept!!!
how to import a fbx without the fbx window???? (ui to big)
5282 8 0- dyei
- 28 posts
- Olaf Finkbeiner
- 323 posts
Minimum resolution: 1920 x 1200 (widescreen).
https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
so if you are on a Laptop you need an external monitor.
greetings
Olaf
greetings
Olaf
- 8045 posts
This came up before in another thread. A work around is to reduce the ui scale, try setting it to compact and see if that helps. Another option is to use the fbximport command from the textport.
http://www.sidefx.com/docs/houdini/commands/fbximport.html [www.sidefx.com]
Edit:
or python
http://www.sidefx.com/docs/houdini/hom/hou/hipFile.html#importFBX [www.sidefx.com]
Edit:
or python
Edited by jsmack - Nov. 19, 2018 11:15:27
- animatrix_
- 4730 posts
Depending on your use case, Agent SOP can also help. It can import an FBX file directly.
- dyei
- 28 posts
Olaf Finkbeiner
greetings
Olaf
- dyei
- 28 posts
jsmackthanks!
Edit:
or python
- AlvinYap
- 56 posts
- skidvis
- sayooj js
