I have a simple geometryimport top set to create work items for each primitive piece attribute from a sop path
This creates a primitiveattribs array containing the names of all the primitive attributes included in ‘copy attributes’ parameter
This all works fine, but how can I get the value of each of those primitive attributes (as they would appear in sops) and set them as work item
? I can only get the attribute name as a string, how would you go about getting the values and creating work item data from them?
If you set the piece attribute as a string, the piecevalue pdg attribute will contain the value of the string. How can I do that for all the other attributes?
geometry import TOP - evaluate sop attribute values
2163 0 0- Neon Junkyards
- 4 posts
