When rendering with Renderman (rman1 ROP), I get a red flag error saying:
could not open the script or pipe
could not write out the script or pipe
failed to complete render : rman1
What's wrong and how can I correct this?
Using Houdini 8.1 and Renderman pro Server 12
thanks,
bern
Houdini + PRMan
5873 7 1- Bernard
- 523 posts
- diula
- 63 posts
- Bernard
- 523 posts
- smokingwillkillyou
- 6 posts
- Bernard
- 523 posts
- Bernard
- 523 posts
- JColdrick
- 4140 posts
I'd simplify, leave Houdini out of the loop and just use the command line “render” to render a RIB you've generated. Odds are this is an rman issue and you should talk to them about it - Houdini might just be confusing the issue. Houdini just uses existing paths to find rman and then relies on pixar's code to deal with licensing issues.
J.C.
J.C.
John Coldrick
- wolfwood
- 4271 posts
The standard test to see if PRMan is working is to go do the following
cd $RMANTREE/etc/setup
make
It will run prman and compare it to a test image to make sure everything is running right. If that doesn't work just give RenderMan Customer Support a call, they are a helpful bunch.
make
