Hey there,
I'm trying to rename multiple nodes that are placed in several directories(subnets) in the network.
For that I'm using Find and Replace in Node Names tool.
It works fine if my nodes are all placed in the same directory.
But if they are in different locations then this tool doesn't find it unless I explicitly tell where to find.
I'm probably missing something .
How do i rename all the nodes in the network, no matter where they are in the network that are matching pattern?
Or maybe for selected nodes? "Find Nodes" works perfectly in finding nodes.
Nodes . Batch rename.
3137 4 2- mikhail s
- 47 posts
- bonsak
- 459 posts
- mikhail s
- 47 posts
- bonsak
- 459 posts
Hi
Im not sure how you can make the search recursive with wildcards but you can enter more than one path at the top:
"/obj/* /obj/*/* /obj/*/*/*"
This will find all 6 nodes in your file.
A little clunky but it works
I thought maybe you could use opchange in the text port but im not sure if opchange can change nodenames. I tried a couple of combos but couldnt figure it out
https://www.sidefx.com/docs/houdini/commands/opchange.html#examples [www.sidefx.com]
-b
-b
- mikhail s
- 47 posts
