Delete Pieces with a volume smaller x
   5961   13   2
I want to delete all pieces of packed geometry with a volume smaller than x. I tried the measurement sop on packed geometry but it does not return any values.
HousDemolition.zip (1.3 MB)
Where is your network showing how you try to delete the small pieces using the measure sop? I looked at your attached project and couldn't find it.
Yep, its REALLY annoying, asked for this to be a feature ages ago, no dice.
You'll either need to unpack, or use the intrinsics, or do a for each bound and transfer measure data, it really should be easier than this.
Edited by mestela - March 3, 2021 17:12:50
goingbananas
Sorry forgot to include that was just a delete sop with a @volume<2 but it only deletes the primitives and not the whole piece so I am stuck with open pieces.
Edited by piosbenni - March 4, 2021 00:56:15
you already have @class attribute so before packing you could do Measure SOP and change Accumulate to Per Piece, then your Blast @volume<2 would delte whole pieces whose volume is < 2 instead of individual polys, then your pack node will just pack whole pieces that are left
however your pieces are not really connected (enclosed/watertight), so connectivity splits the geo into many open pieces, but once you fix that it should work
Edited by tamte - March 4, 2021 01:33:23
mestela
I think we should have some basic statistics functions or intrinsics available. min/max, average, etc. It becomes really tiring to noodle with att promotes or detail wrangles just for these things. I did a feature request a while ago. It would be so useful in this case too.
Jobless
Soothsayer
mestela
Thank you, with some tinkering it worked. Sorry for the delay.
bit fiddly, be nice if it works straight off the shelf.
vu_delSmalls.hipnc (140.7 KB)
vusta
Yes, thanks
Make sure to send an email to support@sidefx.com asking for the measure sop to measure volume of packed geo. The more customers who ask the more it'll bubble to the top of the to-do pile...
@piosbenni
Old Stuff or , maybe it Helps?
OliOdforcetesanSrdjanAsia.hiplc (186.1 KB)
mestela
Okay I will write to them
Librarian
@piosbenni
Yes thank you the vex worked to
 int npts = npoints(0);
float volume;
for(int i = 0; i < npts; i++){
float bounds[] = primintrinsic(0,"bounds",i);
vector min = set(bounds[0],bounds[2],bounds[4]);
vector max = set(bounds[1],bounds[3],bounds[5]);
float x = max.x-min.x;
float y = max.y-min.y;
float z = max.z-min.z;
volume = x*y*z;
setpointattrib(0,"volume",i,volume,"set");
if(volume < chf("volume_limit")){
removepoint(0,i);
Edited by Alexander_Nguyen - March 15, 2021 00:49:32
