My scene was working perfectly fine until this morning when I opened Houdini. I tried to run a flipbook of a flipfluid sim and every time I press start nothing happens. The dialogue box in the lower left corner says “flip book generation error” and nothing else.
If I try to open Mplay, it is delayed, but sends this error out before starting “mantra: unable to clean up temp geometry”.
Anyone have a similar issue before? I've tried deleting pref files but that doesn't seem to help. The flipbook does work in a blank new scene, so I think it is specific to my scene. However, it will only work once - if I reopen the scene and then move to a new scene scene again the same error occurs. The flipbook only works on a fresh restart of Houdini.
Flipbook Generation Error and Mplay Error
12415 7 0- Olm
- 5 posts
- keithlynch_81
- 13 posts
- Anthony Dias
- 5 posts
I just ran into the same issue. MPlay wouldn't even launch.
After copoying and pasting all my nodes into a new Houdini file, MPlay launches, but only 2 frames are outputted to the flipbook.
The error at bottom left says: Flipbook Generation Error: Unable to create image /Users...(project path)
I'm on Houdini 18.5.458 on Mac OSX Catalina if that makes any difference.
- Martin Salfity
- ATOM_cg
- jakeodgers
- 4 posts
Martin Salfity
I was having the same problem on one file. I noticed that for some reason on the Render Flipbook settings I had 'Scoped Channel Key Frames Only' turned on. By default that should be off, switching it back off solved the issue.
GENIUS. I was struggling all morning trying to figure this out and that was the solution. Thanks a million
- bennu
- heyJasonLee
