AMD Radeon ProRender Solaris plugin
   31088   69   4
hshakula
benco
Hey, I just installed the latest version of RPR, and the Material Library doesn't contain a materials.json file, so there's no way to import any material.
I'm on Linux.
Where can I find the materials.json file?
There's a manifest.json file in the library, but one of the keys the import tool is looking for, "dependencies", isn't listed.
I just downloaded the material library from a link specified in the description and it has such folder structure:
/MaterialLibrary
  /Materials
  /Swatches
  /Textures
  /materials.json
What is the manifest.json file you are talking about?
I download the material library from that page from a link in the github:
https://github.com/GPUOpen-LibrariesAndSDKs/RadeonProRenderUSD/releases [github.com]
in the BLENDER area there is that file https://drivers.amd.com/other/radeonprorendermateriallibraryinstaller.run. [drivers.amd.com] I used that one because in the Houdini there's not link for a MATERIAL LIBRARY for some reason.
inside you will find that manifest.json file.
where did you get yours? "from a link in the description" which description are you talking about?
hshakula
When my RPR_MTLX_MATERIAL_LIBRARY_PATH environment variable points to a wrong directory I see such error:
I need to set RPR_MTLX_MATERIAL_LIBRARY_PATH to /MaterialLibrary to get it working:
So please could you please verify that your RPR_MTLX_MATERIAL_LIBRARY_PATH points to the correct directory.
benco
Also, in your documentation, there's a file: asset/basicscene/generated/scene.usda, but there's no mention of where to download it.
You can get it here - https://github.com/hshakula/hdRprDocs. [github.com] But it's definitely should have been hosted on https://radeon-pro.github.io/. [radeon-pro.github.io]
Thanks for the link and yes it will be better with the documentation. Also your hyperlink isn't working because of '.' character at the end. FIXED ONE https://github.com/hshakula/hdRprDocs [github.com] and for the other it should be https://radeon-pro.github.io/RadeonProRenderDocs/en/index.html [radeon-pro.github.io]
Edited by benco - April 15, 2021 14:52:19
benco
Oh, I see, there is the wrong link.
Please download this version instead https://drive.google.com/file/d/1e2Qys1UMi9pu_x3wW5ctm9b8_FIohLKG/view?usp=sharing. [drive.google.com] You can place it anywhere. Just point to the install directory with RPR_MTLX_MATERIAL_LIBRARY_PATH environment variable.
This is a new version of a material library that will replace the old one eventually.
hshakula
benco
I may have missed something, but I have no rpr_uber or materialx available.
Is there any other env to setup to point to the materials folder in the prorender plugin folder(/opt/hdRpr-2.0.27-Houdini-18.5.499-py2.7-ubuntu18.04/materials) where all the mtlx files are?
So far this is my current .json file
{"env":[
{"RPR":"/opt/hdRpr-2.0.27-Houdini-18.5.499-py2.7-ubuntu18.04"},
{"HOUDINI_PATH":"/opt/hdRpr-2.0.27-Houdini-18.5.499-py2.7-ubuntu18.04/houdini"},
{"RPR_MTLX_MATERIAL_LIBRARY_PATH":"/home/fewo/Documents/Radeon ProRender/MaterialLibrary"},
{"PYTHONPATH":"/opt/hdRpr-2.0.27-Houdini-18.5.499-py2.7-ubuntu18.04/lib/python"}
Edited by benco - April 15, 2021 19:15:07
Do you have RPR materials in VOPs at all?
no nothing
Hm, could you please run houdini from the console? Do you see any output?
Only when I try to load the scene file.
Also in the about Houdini details I have that:
Edited by benco - April 15, 2021 20:37:54
I just tested it. Seems like by default Houdini hides all errors/warnings. You need to run
export TF_DEBUG=TF_PRINT_ALL_POSTED_ERRORS_TO_STDERR
before running houdini so that you get errors in console. Specifics of USD in Houdini on Ubuntu.
ok I did but nothing
Also when loading the scene I have that log :
Load warnings for /home/fewo/Documents/3D/ProRender/basicScene/scene.hip
Warning: Bad node type found: RPR::rpr_uberv2 in /stage/materiallibrary1.
/stage/materiallibrary1/rpr_uberv2:
Skipping unrecognized parameter "tabs".
Skipping unrecognized parameter "uber_diffuse_color".
Skipping unrecognized parameter "uber_diffuse_weight".
Skipping unrecognized parameter "uber_diffuse_roughness".
Skipping unrecognized parameter "uber_diffuse_normal".
Skipping unrecognized parameter "uber_reflection_color".
Skipping unrecognized parameter "uber_reflection_weight".
Skipping unrecognized parameter "uber_reflection_roughness".
Skipping unrecognized parameter "uber_reflection_anisotropy".
Skipping unrecognized parameter "uber_reflection_anisotropy_rotation".
Skipping unrecognized parameter "uber_reflection_mode".
Skipping unrecognized parameter "uber_reflection_ior".
Skipping unrecognized parameter "uber_reflection_metalness".
Skipping unrecognized parameter "uber_reflection_normal".
Skipping unrecognized parameter "uber_fresnel_schlick_approximation".
Skipping unrecognized parameter "uber_refraction_color".
Skipping unrecognized parameter "uber_refraction_weight".
Skipping unrecognized parameter "uber_refraction_roughness".
Skipping unrecognized parameter "uber_refraction_ior".
Skipping unrecognized parameter "uber_refraction_normal".
Skipping unrecognized parameter "uber_refraction_thin_surface".
Skipping unrecognized parameter "uber_refraction_absorption_color".
Skipping unrecognized parameter "uber_refraction_absorption_distance".
Skipping unrecognized parameter "uber_refraction_caustics".
Skipping unrecognized parameter "uber_coating_color".
Skipping unrecognized parameter "uber_coating_weight".
Skipping unrecognized parameter "uber_coating_roughness".
Skipping unrecognized parameter "uber_coating_mode".
Skipping unrecognized parameter "uber_coating_ior".
Skipping unrecognized parameter "uber_coating_metalness".
Skipping unrecognized parameter "uber_coating_normal".
Skipping unrecognized parameter "uber_coating_thickness".
Skipping unrecognized parameter "uber_coating_transmission_color".
Skipping unrecognized parameter "uber_sheen".
Skipping unrecognized parameter "uber_sheen_tint".
Skipping unrecognized parameter "uber_sheen_weight".
Skipping unrecognized parameter "uber_emission_color".
Skipping unrecognized parameter "uber_emission_weight".
Skipping unrecognized parameter "uber_emission_mode".
Skipping unrecognized parameter "uber_transparency".
-- Too many errors, additional errors were suppressed. --
Bad node type found: RPR::rpr_uberv2 in /stage/materiallibrary2.
This is the path where all the mtlx are :
3 folders inside /Patterns /Shaders /Utilities.
Do I need to setup those env variables:
### Usdview plugin
Here and next, HDRPR_PACKAGE_DIR is a path to the root of the package.
* Set `RPR` environment variable to `HDRPR_PACKAGE_DIR`
* Add `HDRPR_PACKAGE_DIR/plugin` path entry to the `PXR_PLUGINPATH_NAME` environment variable
* Add `HDRPR_PACKAGE_DIR/lib/python` path entry to the `PYTHONPATH` environment variable
* Windows only: add the `HDRPR_PACKAGE_DIR/lib` path entry to the `PATH` environment variable
Edited by benco - April 16, 2021 16:35:22
benco
For Houdini you need slightly different set of env vars. You already have it here:
benco
{"env":[
I've prepared a build with additional logging added to the code that registers material nodes for Houdini: https://drive.google.com/file/d/1XxWea5J__VCYNLFGbKP8V5SQRq3_tRMw/view?usp=sharing [drive.google.com] (let me know if this build will not work for you, I will create a build on the build server)
Before running houdini from the console with this build, run this command:
export "TF_DEBUG=RPR_USD_DEBUG_MATERIAL_REGISTRY TF_PRINT_ALL_POSTED_ERRORS_TO_STDERR"
Edited by hshakula - April 17, 2021 12:10:15
hshakula
benco
benco
{"env":[
Thank you for the new build !!!
hshakula
So I did install the new build, and here is the log output:
Registering material node with id "UsdPreviewSurface"
Registering material node with id "UsdPrimvarReader_float2"
Registering material node with id "UsdTransform2d"
Registering material node with id "UsdUVTexture"
Registering material node with id "rpr_shadow_catcher"
Registering material node with id "rpr_reflection_catcher"
Registering material node with id "rpr_displace"
Registering material node with id "rpr_materialx_node"
Registering material node with id "rpr_arithmetic_normalize3"
Registering material node with id "rpr_arithmetic_length3"
Registering material node with id "rpr_arithmetic_sin"
Registering material node with id "rpr_arithmetic_cos"
Registering material node with id "rpr_arithmetic_tan"
Registering material node with id "rpr_arithmetic_log"
Registering material node with id "rpr_arithmetic_atan"
Registering material node with id "rpr_arithmetic_asin"
Registering material node with id "rpr_arithmetic_acos"
Registering material node with id "rpr_arithmetic_abs"
Registering material node with id "rpr_arithmetic_floor"
Registering material node with id "rpr_arithmetic_average_xyz"
Registering material node with id "rpr_arithmetic_select_x"
Registering material node with id "rpr_arithmetic_select_y"
Registering material node with id "rpr_arithmetic_select_z"
Registering material node with id "rpr_arithmetic_select_w"
Registering material node with id "rpr_arithmetic_shuffle_yzwx"
Registering material node with id "rpr_arithmetic_shuffle_zwxy"
Registering material node with id "rpr_arithmetic_shuffle_wxyz"
Registering material node with id "rpr_arithmetic_mat_mul"
Registering material node with id "rpr_arithmetic_combine"
Registering material node with id "rpr_arithmetic_ternary"
Registering material node with id "rpr_arithmetic_mod"
Registering material node with id "rpr_arithmetic_div"
Registering material node with id "rpr_arithmetic_average"
Registering material node with id "rpr_arithmetic_dot4"
Registering material node with id "rpr_arithmetic_and"
Registering material node with id "rpr_arithmetic_mul"
Registering material node with id "rpr_arithmetic_greater"
Registering material node with id "rpr_arithmetic_max"
Registering material node with id "rpr_arithmetic_min"
Registering material node with id "rpr_arithmetic_add"
Registering material node with id "rpr_arithmetic_equal"
Registering material node with id "rpr_arithmetic_or"
Registering material node with id "rpr_arithmetic_sub"
Registering material node with id "rpr_arithmetic_lower_or_equal"
Registering material node with id "rpr_arithmetic_dot3"
Registering material node with id "rpr_arithmetic_cross3"
Registering material node with id "rpr_arithmetic_pow"
Registering material node with id "rpr_arithmetic_lower"
Registering material node with id "rpr_arithmetic_greater_or_equal"
Registering material node with id "rpr_arithmetic_not_equal"
Registering material node with id "rpr_combine"
RPR: /opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_microfacet_refraction.mtlx"
Registering material node with id "rpr_microfacet_refraction"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_emissive.mtlx"
Registering material node with id "rpr_emissive"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_diffuse.mtlx"
Registering material node with id "rpr_diffuse"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_microfacet_anisotropic_reflection.mtlx"
Registering material node with id "rpr_microfacet_anisotropic_reflection"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_orennayar.mtlx"
Registering material node with id "rpr_orennayar"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_add.mtlx"
Registering material node with id "rpr_add"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_volume.mtlx"
Registering material node with id "rpr_volume"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_refraction.mtlx"
Registering material node with id "rpr_refraction"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_passthrough.mtlx"
Registering material node with id "rpr_passthrough"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_ward.mtlx"
Registering material node with id "rpr_ward"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_microfacet_anisotropic_refraction.mtlx"
Registering material node with id "rpr_microfacet_anisotropic_refraction"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_reflection.mtlx"
Registering material node with id "rpr_reflection"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_uber.mtlx"
Registering material node with id "rpr_uberv2"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_transparent.mtlx"
Registering material node with id "rpr_transparent"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_blend.mtlx"
Registering material node with id "rpr_blend"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_microfacet.mtlx"
Registering material node with id "rpr_microfacet"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_phong.mtlx"
Registering material node with id "rpr_phong"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_diffuse_refraction.mtlx"
Registering material node with id "rpr_diffuse_refraction"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Shaders/rpr_microfacet_beckmann.mtlx"
Registering material node with id "rpr_microfacet_beckmann"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Patterns/rpr_gradient_texture.mtlx"
Registering material node with id "rpr_gradient_texture"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Patterns/rpr_checker_texture.mtlx"
Registering material node with id "rpr_checker_texture"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Patterns/rpr_noise2d_texture.mtlx"
Registering material node with id "rpr_noise2d_texture"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Patterns/rpr_dot_texture.mtlx"
Registering material node with id "rpr_dot_texture"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_blend_value.mtlx"
Registering material node with id "rpr_blend_value"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_twosided.mtlx"
Registering material node with id "rpr_twosided"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_uv_procedural.mtlx"
Registering material node with id "rpr_uv_procedural"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_rgb_to_hsv.mtlx"
Registering material node with id "rpr_rgb_to_hsv"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_constant_texture.mtlx"
Registering material node with id "rpr_constant_texture"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_bump_map.mtlx"
Registering material node with id "rpr_bump_map"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_uv_triplanar.mtlx"
Registering material node with id "rpr_uv_triplanar"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_fresnel_schlick.mtlx"
Registering material node with id "rpr_fresnel_schlick"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_hsv_to_rgb.mtlx"
Registering material node with id "rpr_hsv_to_rgb"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_fresnel.mtlx"
Registering material node with id "rpr_fresnel"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_normal_map.mtlx"
Registering material node with id "rpr_normal_map"
Processing material: "/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/materials/Utilities/rpr_input_lookup.mtlx"
Registering material node with id "rpr_input_lookup"
[MSG  @RIF]: Loaded RIF API version: 1.6.1.0xe4886697
None of the rpr_ node are visible in the material area in houdini
benco
That's because you are missing one critical part. Interesting. Looks like, for some reason, your Houdini does not call this function https://github.com/GPUOpen-LibrariesAndSDKs/RadeonProRenderUSD/blob/master/pxr/imaging/plugin/rprHoudini/plugin.cpp#L22 [github.com]
Please run this too as part of the environment setup
export HOUDINI_DSO_ERROR=3
hshakula
benco
DSO_INFO:Running installFSHelpers() in path[1] with fs/USD_FS.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Find installFSHelpers()
DSO_INFO:/opt/hfs18.5/houdini/dso/fs/USD_FS.so:Calling installFSHelpers()
DSO_INFOONE Running installFSHelpers() in path[1] with fs/USD_FS.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_IPlay.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IPlay.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_IPlay.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_MDisplay.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_MDisplay.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_MDisplay.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_JPEG.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_JPEG.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_JPEG.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_Cineon.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Cineon.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_Cineon.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_Wave.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Wave.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_Wave.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_Alias.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Alias.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_Alias.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_Bitmap.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Bitmap.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_Bitmap.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_SoftImage.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_SoftImage.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_SoftImage.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_Targa.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Targa.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_Targa.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_Vertigo.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_Vertigo.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_Vertigo.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_RADIANCE.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_RADIANCE.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_RADIANCE.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_OpenEXR.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OpenEXR.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_OpenEXR.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_OIIO.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_OIIO.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_OIIO.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_PNG.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_PNG.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_PNG.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_ptex.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_ptex.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_ptex.so
DSO_INFO:Running newIMGFormat() in path[2] with IMG_IOTable.so
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Find newIMGFormat()
DSO_INFO:/opt/hfs18.5/houdini/dso/fb/IMG_IOTable.so:Calling newIMGFormat()
DSO_INFOONE Running newIMGFormat() in path[2] with IMG_IOTable.so
DSO_INFO:libpython2.7.so.1.0:Attempt load
DSO_INFO:libpython2.7.so.1.0:Loaded
DSO_INFO:Running newModelState() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/home/fewo/houdini18.5/dso.cache:Loaded cache
DSO_INFO:/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/houdini/dso/RPR_for_Houdini.so:Attempt load
Houdini DSO error on '/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/houdini/dso/RPR_for_Houdini.so'
	librprUsd.so: cannot open shared object file: No such file or directory
DSO_INFOONE Running newModelState() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newHandle() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newHandle() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newOpHandleLink() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newOpHandleLink() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newOpHandleBinding() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newOpHandleBinding() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newSelector() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newSelector() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running HOMextendLibrary() in reverse order in search path
DSO_INFOONE Running HOMextendLibrary() in reverse order in search path
DSO_INFO:Running GUregisterAgentCustomDataItemType() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running GUregisterAgentCustomDataItemType() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running GUregisterAgentShapeDeformer() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running GUregisterAgentShapeDeformer() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newGeometryIO() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Find newGeometryIO()
DSO_INFO:/opt/hfs18.5/houdini/dso/GEO_DEMIO.so:Calling newGeometryIO()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Find newGeometryIO()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling newGeometryIO()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Find newGeometryIO()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Calling newGeometryIO()
DSO_INFOONE Running newGeometryIO() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newGeometryPrim() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Find newGeometryPrim()
DSO_INFO:/opt/hfs18.5/houdini/dso/GU_Alembic.so:Calling newGeometryPrim()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Find newGeometryPrim()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling newGeometryPrim()
DSO_INFOONE Running newGeometryPrim() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running CMDextendLibrary() in reverse order in search path
DSO_INFOONE Running CMDextendLibrary() in reverse order in search path
DSO_INFO:Running newDopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newDopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running initializeSIM() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Find initializeSIM()
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Calling initializeSIM()
DSO_INFOONE Running initializeSIM() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newObjectOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Find newObjectOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/OBJ_ReLight.so:Calling newObjectOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Find newObjectOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling newObjectOperator()
DSO_INFOONE Running newObjectOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newSopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Attempt load
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Loaded
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VolumeArrivalTime.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicGroup.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Alembic.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SIM_SolverBullet.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_LidarImport.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDB.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_InstantMeshes.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_FindShortestPath.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_AlembicPrimitive.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_GLTF.so:Calling newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Find newSopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/FLU_Filament.so:Calling newSopOperator()
DSO_INFOONE Running newSopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newDriverOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Find newDriverOperator()
DSO_INFO:/opt/hfs18.5/packages/kinefx/dso/kinefx.so:Calling newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Find newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Alembic.so:Calling newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Find newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_OpenGL.so:Calling newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Find newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_GLTF.so:Calling newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Find newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_Agent.so:Calling newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Find newDriverOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/ROP_FBX.so:Calling newDriverOperator()
DSO_INFOONE Running newDriverOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newChopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newChopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newChopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Find newChopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Mouse3D.so:Calling newChopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Find newChopOperator()
DSO_INFO:/opt/hfs18.5/houdini/dso/CHOP_Gamepad.so:Calling newChopOperator()
DSO_INFOONE Running newChopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newShopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newShopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newShopClerk() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newShopClerk() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newCopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newCopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newCop2Operator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Find newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_Substance.so:Calling newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Find newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUEnvironment.so:Calling newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Find newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUFog.so:Calling newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Find newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPUZComposite.so:Calling newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Find newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_EnableGPU.so:Calling newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Find newCop2Operator()
DSO_INFO:/opt/hfs18.5/houdini/dso/COP2_GPULighting.so:Calling newCop2Operator()
DSO_INFOONE Running newCop2Operator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newVopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newVopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newVopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newVopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newLopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newLopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newAutoCollection() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Find newAutoCollection()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling newAutoCollection()
DSO_INFOONE Running newAutoCollection() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newTopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newTopNetOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newTopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newTopOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
fewo@cg-workstation:/opt/hfs18.5$ DSO_INFO:Running registerPDGTypes() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Find registerPDGTypes()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_NodeTypes.so:Calling registerPDGTypes()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Find registerPDGTypes()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdg/PDG_SchedulerTypes.so:Calling registerPDGTypes()
DSO_INFOONE Running registerPDGTypes() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running registerPDGDTypes() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Find registerPDGDTypes()
DSO_INFO:/opt/hfs18.5/houdini/dso/pdgd/PDGD_Types.so:Calling registerPDGDTypes()
DSO_INFOONE Running registerPDGDTypes() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running CLregisterClipReader() in reverse order in search path
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Find CLregisterClipReader()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_AudiereClipReader.so:Calling CLregisterClipReader()
DSO_INFOONE Running CLregisterClipReader() in reverse order in search path
DSO_INFO:Running CLregisterClipWriter() in reverse order in search path
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Find CLregisterClipWriter()
DSO_INFO:/opt/hfs18.5/houdini/dso/audio/CL_SndfileClipWriter.so:Calling CLregisterClipWriter()
DSO_INFOONE Running CLregisterClipWriter() in reverse order in search path
DSO_INFO:Running newManagerOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newManagerOperator() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newRenderOption() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newRenderOption() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newRenderHook() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Finding HoudiniDSOVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Calling HoudiniDSOVersion
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Finding HoudiniCompilerVersion()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:HoudiniDSOVersion() and HoudiniCompilerVersion() check success
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Find newRenderHook()
DSO_INFO:/opt/hfs18.5/houdini/dso/SOP_VDBUI.so:Calling newRenderHook()
DSO_INFOONE Running newRenderHook() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running DMnewEventHook() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running DMnewEventHook() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:Running newVisualizerType() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFOONE Running newVisualizerType() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
fewo@cg-workstation:/opt/hfs18.5$ DSO_INFO:libHoudiniPRM.so:Attempt load
DSO_INFO:libHoudiniPRM.so:Loaded
DSO_INFO:libHoudiniGEO.so:Attempt load
DSO_INFO:libHoudiniGEO.so:Loaded
DSO_INFO:libHoudiniRAY.so:Attempt load
DSO_INFO:libHoudiniRAY.so:Loaded
DSO_INFO:Running newVEXOp() in path[1] with /opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so
DSO_INFO:/opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so:Attempt load
DSO_INFO:/opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so:Loaded
DSO_INFO:/opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so:Finding HoudiniDSOInit()
DSO_INFO:/opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so:Find newVEXOp()
DSO_INFO:/opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so:Calling newVEXOp()
DSO_INFOONE Running newVEXOp() in path[1] with /opt/hfs18.5/houdini/dso/vex/VEX_OpRender.so
DSO_INFO:Running newStageFactory() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Find newStageFactory()
DSO_INFO:/opt/hfs18.5/houdini/dso/USD_Ops.so:Calling newStageFactory()
DSO_INFOONE Running newStageFactory() in HOUDINI_DSO_PATH, HOUDINI_IMAGE_DSO_PATH, HOUDINI_AUDIO_DSO_PATH
One error is :
Edited by benco - April 17, 2021 15:02:04
That's what we were looking for - root of the evil. Here's a new build with a fix - https://wetransfer.com/downloads/2f9620370d9cfa62eb22810e478be2d420210417201236/ced838a47ab58cc161b7b6bad3178dc120210417201252/07360a [wetransfer.com]
Ok now getting close but still no nodes.
/opt/hdRpr-2.0.36-Houdini-18.5.532-py2.7-ubuntu20.04/houdini/dso/RPR_for_Houdini.so: undefined symbol: _ZN8VOP_Node16getErrorSeverityEv
Edited by benco - April 17, 2021 16:28:26
benco
Hm, are you on houdini 18.5.532?
NO I'm on 18.5.499 I just realized that you sent me packages for .532, the original release link on the github for ProRender is for the .499
benco
build for 499 - https://drive.google.com/file/d/180LYm1ITZP40jlZbgYZ50dq0plrFwArm/view?usp=sharing [drive.google.com]
Hshakula Thank you so much !!! everything seems to work now as expected.
